Hi guys, I have been trying to configure RapidMiner Ai hub server with Prometheus to monitor and collect metrics. I was following the steps from the RapidMiner Ai hub documentation for monitoring. I have added the scrape configs as mentioned in the documentation and also added
SPRING_PROFILES_ACTIVE=default,webapi, prometheus in the .env file. But in prometheus, the target is down. It shows 404 or 502 error.- job_name: aihubs
scrape_interval: 30s
scrape_timeout: 10s
metrics_path: /system/prometheus
static_configs:
- targets: ['${PROMETHEUS_ADDRESS}']
labels:
instance: 'aihub1'
