Coloring IO object data
User: "Haoyang"
New Altair Community Member
Updated by Jocelyn
I defined an IOobject datatype, and assigned a color to it, I find it when there is too much lines consisting this type of data in a process, the previous lines will not show the correct color and this data was removed from the output of the operator(no data when I hover my mouse above the output port). It seems RM only render the last few lines that carries this type of data. I also tested this with breakpoints, I connected several operators outputting this same type of object, and have a breakpoint for each of them, when I executed the operators one by one, the first four operators have normal output line color. However, when I executed the fifth operator, the color for the first one returned to gray which was the default. Sometimes, this breakpoint method have kept all the color and sometimes not, if I don't set the breakpoint and execute the process as a whole, there will only be the last 4 lines colored. Also, even in the case where all the colors were kept because of the breakpoint, when I go to the higher process and return to this subprocess, the color will again only available to the last 4 lines. It seems that you have used a buffer or what and have cleared them after execution, without keeping the color.
Best,
Haoyang
1 - 4 of 41
