Valdiation of the model and adjusted R Squared
Hey Community,
I have a question regarding the validation of my model (I used the cross validation operator).
I created a prediction model (label: numeric) and therfore used the algorithms "Linear Regression, "Neural Net" and "Deep Learning". For validation I chose the RMSE, the relative error and the squared correlation (R squared).
I read that the R squared gets better as more attributes are chosen. To prevent this, I read that the adjusted R squared should be chosen. Is this possible with RapidMiner Studio or is this already the adjusted R squared?
To improve my model I also tested with the "Select attributes" operator and noticed the following:
When I selected all attributes I had this performance:
Case 1
Linear Regression (RMSE 0,8 I Relative Error 14,2 I R squared 0,63)
Neural Net (RMSE 0,86 I RF 15,91 I R squared 0,65)
Deep Learning (RMSE 0,78 I RF 11,72 I R squared 0,68)
In this case the Deep Learning should be the best model.
Now I removed some attributes for modeling and got the following results:
Case 2
Linear Regression (RMSE 0,79 I Relative Error 14,0 I R squared 0,68)
Neural Net (RMSE 0,89 I RF 17,29 I R squared 0,66)
Deep Learning (RMSE 0,79 I RF 13,19 I R squared 0,65)
I do not really know if the Linear Regression in second case is the better model as the Deep Learning in first case (R squared got better but Relative Error got worse). Can somebody help?
Thanks a lot!
