I am trying to connect Radoop to my Cloudera Cluster on MS Azure having Spark 2.4. All test went well but I got an error in Spark test (spark staging directory error).
Nov 24, 2019 10:55:31 PM]: Test succeeded: Fetch dynamic settings (9.605s)
[Nov 24, 2019 10:55:31 PM]: Running test 2/5: Spark staging directory
[Nov 24, 2019 10:55:32 PM] SEVERE: Test failed: Spark staging directory
[Nov 24, 2019 10:55:32 PM]: Cleaning after test: Spark staging directory
[Nov 24, 2019 10:55:32 PM]: Cleaning after test: Fetch dynamic settings
[Nov 24, 2019 10:55:32 PM]: Total time: 10.100s
[Nov 24, 2019 10:55:32 PM]: java.lang.IllegalArgumentException: java.net.UnknownHostException: sibaluster-50e44e52.siba
at org.apache.hadoop.security.SecurityUtil.buildTokenService(SecurityUtil.java:418)
at org.apache.hadoop.hdfs.NameNodeProxiesClient.createProxyWithClientProtocol(NameNodeProxiesClient.java:130)
at org.apache.hadoop.hdfs.DFSClient.<init>(DFSClient.java:343)
at org.apache.hadoop.hdfs.DFSClient.<init>(DFSClient.java:287)
at org.apache.hadoop.hdfs.DistributedFileSystem.initialize(DistributedFileSystem.java:156)
at org.apache.hadoop.fs.FileSystem.createFileSystem(FileSystem.java:2811)
at org.apache.hadoop.fs.FileSystem.access$200(FileSystem.java:100)
at org.apache.hadoop.fs.FileSystem$Cache.getInternal(FileSystem.java:2848)
at org.apache.hadoop.fs.FileSystem$Cache.get(FileSystem.java:2830)
at org.apache.hadoop.fs.FileSystem.get(FileSystem.java:389)
at org.apache.hadoop.fs.FileSystem.get(FileSystem.java:181)
at eu.radoop.datahandler.mapreducehdfs.MRHDFSHandlerLowLevel.testDirPermission(MRHDFSHandlerLowLevel.java:786)
at eu.radoop.datahandler.mapreducehdfs.MRHDFSHandlerLowLevel.testSparkStagingPermission_invoke(MRHDFSHandlerLowLevel.java:766)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at eu.radoop.datahandler.mapreducehdfs.MRHDFSHandlerLowLevel$2.run(MRHDFSHandlerLowLevel.java:641)
at java.security.AccessController.doPrivileged(Native Method)
at javax.security.auth.Subject.doAs(Subject.java:422)
at org.apache.hadoop.security.UserGroupInformation.doAs(UserGroupInformation.java:1807)
at eu.radoop.security.UgiWrapper.doAs(UgiWrapper.java:49)
at eu.radoop.datahandler.mapreducehdfs.MRHDFSHandlerLowLevel.invokeAs(MRHDFSHandlerLowLevel.java:637)
at eu.radoop.datahandler.mapreducehdfs.MapReduceHDFSHandler.invokeAs(MapReduceHDFSHandler.java:1805)
at eu.radoop.datahandler.mapreducehdfs.MapReduceHDFSHandler.invokeAs(MapReduceHDFSHandler.java:1769)
at eu.radoop.datahandler.mapreducehdfs.MapReduceHDFSHandler.invokeAs(MapReduceHDFSHandler.java:1746)
at eu.radoop.datahandler.mapreducehdfs.MapReduceHDFSHandler.invoke(MapReduceHDFSHandler.java:1733)
at eu.radoop.datahandler.mapreducehdfs.MapReduceHDFSHandler.lambda$testStagingDirPermission$32(MapReduceHDFSHandler.java:1522)
at eu.radoop.tools.ExceptionTools.checkOnly(ExceptionTools.java:277)
at eu.radoop.datahandler.mapreducehdfs.MapReduceHDFSHandler.testStagingDirPermission(MapReduceHDFSHandler.java:1521)
at eu.radoop.datahandler.mapreducehdfs.MapReduceHDFSHandler.testSparkStagingPermission(MapReduceHDFSHandler.java:1513)
at eu.radoop.connections.service.test.connection.TestSparkStaging.call(TestSparkStaging.java:45)
at eu.radoop.connections.service.test.connection.TestSparkStaging.call(TestSparkStaging.java:24)
at eu.radoop.connections.service.test.RadoopTestContext.lambda$runTest$1(RadoopTestContext.java:282)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.net.UnknownHostException: sibaluster-50e44e52.siba
... 42 more
[Nov 24, 2019 10:55:32 PM] SEVERE: java.lang.IllegalArgumentException: java.net.UnknownHostException: sibaluster-50e44e52.siba
[Nov 24, 2019 10:55:32 PM] SEVERE: Spark staging directory (on HDFS) test failed. The Radoop client tried to write the HDFS user home directory.
[Nov 24, 2019 10:55:32 PM] SEVERE: Integration test for 'sibaucluster (10.1.7.8)' failed.
