Just downloaded the Linux version of RapidMiner (Free) - Studio Version 9.2. When running the ./RapidMiner-Studio.sh, RapidMiner launches but hangs on 'Initializing Plugin GUI'. The last entry in the terminal is:
INFO: Community repository 'Training Resources' added.
I have read several articles and have taken the following actions:
Changed permissions:
set chmod +x RapidMiner-Studio.sh
Edited /etc/environment to include the following line:
JAVA_HOME="java-8-openjdk-amd64"
source /etc/environment
echo $JAVA_HOME provides the following results:
Please note, I also have OpenJDK 10.0.2 installed.
In addition, I edited the RapidMiner-Studio.sh and added the following to the lines below: --add-modules=java.xml.bind
# Launch Studio
LAUNCH=0
if [ $# -gt 0 ]; then
eval \"$JAVA\" --add-modules=java.xml.bind $JVM_OPTIONS -cp \"${rmClasspath}\" com.rapidminer.launcher.GUILauncher \"$@\"
else
fi
if [ $? -eq 2 ]
then
echo RapidMiner Studio will now relaunch
LAUNCH=1
fi
done
I have also tried deleting all of the files in the .RapidMiner folder and relaunching RapidMiner.
Lastly, I tried running RapidMiner without loading the extensions (Disable extension button) and RapidMiner continues hangs on 'Initializing Plugin GUI'.
Any guidance would be greatly appreciated.
Thanks!
