<?xml version="1.0" encoding="UTF-8"?><process version="8.2.000"> <context> <input/> <output/> <macros> <macro> <key>url</key> <value/> </macro> <macro> <key>user</key> <value/> </macro> <macro> <key>pass</key> <value/> </macro> </macros> </context> <operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="jdbc_connectors:read_database" compatibility="8.2.000" expanded="true" height="68" name="Read Database" width="90" x="380" y="34"> <parameter key="define_connection" value="url"/> <parameter key="database_url" value="%{url}"/> <parameter key="username" value="%{user}"/> <parameter key="password" value="ZGmujF5bm8M="/> <enumeration key="parameters"/> </operator> <connect from_op="Read Database" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
