At some point the behaviour of these operators has changed in more recent versions of Rapidminer. I am losing repeatability. Of all the learners I tested, these are the ones that did not give me the same results between RM7.1 and RM8+. At least on my data. The results are the same if repeated on each version of Rapidminer independently so the process is not introducing any randomness. Unfortunately, I get consistently better results from the versions in 7.1 than in newer versions. I am assuming that I could create an extension for these older operators. Is there a better way?
Kind regards,
Alex
Alex
