"[SOLVED]Problem with the extension tutorial"
Hi all,
i try to learn how to write extension for RapidMiner, but I have a problem with the Tutorial "How to extend rapidminer", the Chapter 2 "Using the Scripting Operator" used a "Log" data set as example set, but I can not find where I can download the data set. Can you tell me, where are the example data sets and where are the example codes?
Thanks very much!
Conny
