How to export folder view of cluster method to excel file ?
asimk
asimk New Altair Community Member
edited November 2024 in Altair RapidMiner
I performed k-means cluster method on RapidMiner. I want to export data on Folder View to txt or excel file. How can I do that?
http://imgur.com/HsbOiym
http://imgur.com/h22N6VU
<process version="5.3.015">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
   <process expanded="true">
     <operator activated="true" class="loop_files" compatibility="5.3.015" expanded="true" height="94" name="Loop Files" width="90" x="45" y="30">
       <parameter key="directory" value="C:\Users\kasim\Desktop\118bus"/>
         <operator activated="true" class="read_excel" compatibility="5.3.015" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
           <parameter key="first_row_as_names" value="false"/>
           <list key="annotations">
             <parameter key="0" value="Unit"/>
           </list>
           <list key="data_set_meta_data_information"/>
         <operator activated="true" class="normalize" compatibility="5.3.015" expanded="true" height="94" name="Normalize" width="90" x="179" y="30">
           <parameter key="create_view" value="true"/>
         <operator activated="true" class="fast_k_means" compatibility="5.3.015" expanded="true" height="76" name="Clustering" width="90" x="380" y="30">
           <parameter key="add_as_label" value="true"/>
           <parameter key="k" value="3"/>
         <connect from_port="file object" to_op="Read Excel" to_port="file"/>
         <connect from_op="Read Excel" from_port="output" to_op="Normalize" to_port="example set input"/>
         <connect from_op="Normalize" from_port="example set output" to_op="Clustering" to_port="example set"/>
         <connect from_op="Clustering" from_port="cluster model" to_port="out 1"/>
         <connect from_op="Clustering" from_port="clustered set" to_port="out 2"/>
         <portSpacing port="source_file object" spacing="0"/>
         <portSpacing port="sink_out 3" spacing="0"/>
       </process>
     <connect from_op="Loop Files" from_port="out 1" to_port="result 1"/>
     <connect from_op="Loop Files" from_port="out 2" to_port="result 2"/>
   </process>
</process>
How can I accomplish this?
~Thanks~
