<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.015" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="90"> <list key="attribute_values"> <parameter key="Dept" value=""Name_and_Role""/> <parameter key="Institution" value=""ABC""/> <parameter key="OldKey" value=""abc_1""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="replace" compatibility="5.3.015" expanded="true" height="76" name="Replace Comma" width="90" x="179" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Dept"/> <parameter key="replace_what" value="','"/> <parameter key="replace_by" value="_"/> </operator> <operator activated="true" class="replace" compatibility="5.3.015" expanded="true" height="76" name="Remove punctation" width="90" x="313" y="120"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Dept"/> <parameter key="attributes" value="|Dept"/> <parameter key="replace_what" value=" [-!"#$%&'()*+,./:;<=>?@\[\\\]_`{|}~]"/> </operator> <operator activated="true" class="replace" compatibility="5.3.015" expanded="true" height="76" name="Replace space" width="90" x="447" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Dept"/> <parameter key="attributes" value="|Dept"/> <parameter key="replace_what" value=" "/> <parameter key="replace_by" value="_"/> </operator> <operator activated="true" breakpoints="before,after" class="set_macro" compatibility="5.3.015" expanded="true" height="76" name="Set Macro" width="90" x="581" y="165"> <parameter key="macro" value="macFileName"/> <parameter key="value" value="str(Institution) + "_" + str(Dept) +" _" + str(OldKey) +".txt""/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Replace Comma" to_port="example set input"/> <connect from_op="Replace Comma" from_port="example set output" to_op="Remove punctation" to_port="example set input"/> <connect from_op="Remove punctation" from_port="example set output" to_op="Replace space" to_port="example set input"/> <connect from_op="Replace space" from_port="example set output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
