Good afternoon - my corporate firewall blocks access to the Update RapidMiner option. The symptom is when I choose Update RapidmIner, the Progress box sticks on "Fetching Updates" for a timeout period, before returning "Cannot contact update server. Reason: Connection timed out: connect".
The same operation works fine from home using my personal Internet connection (no corporate firewall).
I specifically am looking to get the Text Processing extension configured. Are there instructions for manually downloading and configuring the extension, or an option to download and install extensions (in general) and/or Text Processing in particular?
Thanks for the help,
Asoka
The details from Show Details:
Exception: javax.xml.ws.WebServiceException
Message: Failed to access the WSDL at:
http://rapidupdate.de:80/UpdateServer/UpdateServiceService?wsdl. It failed with:
Connection timed out: connect.
Stack trace:
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.tryWithMex(Unknown Source)
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(Unknown Source)
com.sun.xml.internal.ws.client.WSServiceDelegate.parseWSDL(Unknown Source)
com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(Unknown Source)
com.sun.xml.internal.ws.spi.ProviderImpl.createServiceDelegate(Unknown Source)
javax.xml.ws.Service.<init>(Unknown Source)
com.rapidminer.deployment.client.wsimport.UpdateServiceService.<init>(UpdateServiceService.java:37)
com.rapid_i.deployment.update.client.UpdateManager.getService(UpdateManager.java:343)
com.rapid_i.deployment.update.client.UpdateDialog$3.run(UpdateDialog.java:117)
com.rapidminer.gui.tools.ProgressThread$2.run(ProgressThread.java:189)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
Cause
Exception: java.net.ConnectException
Message: Connection timed out: connect
Stack trace:
java.net.PlainSocketImpl.socketConnect(Native Method)
java.net.PlainSocketImpl.doConnect(Unknown Source)
java.net.PlainSocketImpl.connectToAddress(Unknown Source)
java.net.PlainSocketImpl.connect(Unknown Source)
java.net.SocksSocketImpl.connect(Unknown Source)
java.net.Socket.connect(Unknown Source)
sun.net.NetworkClient.doConnect(Unknown Source)
sun.net.www.http.HttpClient.openServer(Unknown Source)
sun.net.www.http.HttpClient.<init>(Unknown Source)
sun.net.www.http.HttpClient.New(Unknown Source)
sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
java.net.URL.openStream(Unknown Source)
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.createReader(Unknown Source)
com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.resolveWSDL(Unknown Source)
