HG Axis LockGuard - permanent axis range lock
User: "Sebastian_Karp"
Updated by Sebastian_Karp
Overview
This Extension provides a toolbar with buttons to turn the "Axis LockGuard" ON/OFF (available since HG2023.1).
The TCL commands that are used in the background are:
[::hwplot::GetPlotManagerHandle] SetFitAxesLockGuard true
[::hwplot::GetPlotManagerHandle] SetFitAxesLockGuard false
Pre-Requisite
Download and un-zip attached Extension package.
Add Extension through HW GUI by opening the Extension Manager.
Use "Add Extension" and select the folder where  extension.xml  is located.
Then turn it ON by button.
This will make the toolbar available with buttons for Axis LockGuard ON/OFF.
Top button will turn ON the LockGuard, and the axis ranges for both X/Y axes will be locked and kept, independent of the following action (plot new curve, copy/paste curve, ...).
Bottom button will turn LockGuard OFF and default HG axis range behaviour is used again.
Axes ranges stay locked.
Comments
No comments on this post.
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
