Hello
I am currently investigating the interaction between blood and blood vessel walls using RADIOSS.
I would like to output the shear stress exerted by the fluid on the structural wall in both graph and animation formats. How should I set this up?
Hi Yuki Kaneko,
Hi Yuki Kaneko, In Radioss we can output the shear stress using below keyword in engine file. /ANIM/SHELL/SIGXY /ANIM/SHELL/SIGYZ /ANIM/SHELL/SIGZX For solid elements use /ANIM/BRICK/SIGXY .. Regards Harish
Hi Harish,
Thank you for your advice.
Is it possible to plot the time history of stress on an element?
Best regards
Yuki
