contact slip analysis
Sid_22073
Sid_22073 Altair Community Member
edited May 2023 in Community Q&A
I want to find the torque required for the slip of the interference fit.
Could someone help me how can I do it.
If Could you please provide me any short sample opristruct deck (.fem file) or explain detail will help me.
I saw some of the posts earlier, but could not understand fully.
Thanks and I appriciate your help in advance !!
THanks for the help.
Looking forward for your reply.
Best Answer
  • Adriano_Koga
    Adriano_Koga
    edited May 2023 Answer ✓
    Sid_22073 said:
    I have run 2 cases with SLIDING and with friction 0.12 between the pairs.
    Please see the results below of the reaction moments about X axis.
    The curves are pretty straight, I would rather expect a quadratic curve i.e increase in torque and after some time the torque decreases
    Is my problem setup correct ?
    Please note I applied SPCD of 6.28319 radian ie 360 degrees
    can somebody help to resolve this if not correct ?
    I did this small model here.
    I got a decrease in the torque after some rotation.
    I have 2 loadcases:
    - press-fit
    - rotation continuing from LC1
    on the right corner in the bottom you will see torque x rotation
  • Adriano_Koga
    Adriano_Koga
    edited April 2023
    could you add a few more details on what are you trying to accomploish, and maybe add some pictures?
    If you want one part to be iserted into another, you will need a LGDISP contact with Continuous or Finite Sliding at least.
    But with so few details it is hard to give you more insights.
  • Sid_22073
    edited April 2023
    The pin (middle part) is assembled by an interference fit.
    I want to now check how much torque this pin can withstand before slipping. For this want to apply torque at both ends of pin along the axis and somehow get the reaction forces and plot this in graph. I would like to see a no-linear curve ( timestep vs reaction force)
    Please check the following .fem file and let me know if run correct.
    First subcase is for contact
    2nd subcase is for contact + moment
    $$ optistruct
    CONTF(H3D,PCONT) = YES
    CSTRESS(H3D,ALL,NDIV=1) = ALL
    DISPLACEMENT(H3D) = ALL
    GPSTRESS(H3D) = ALL
    SPCFORCE(H3D) = 5
    STRESS(H3D) = YES
    $$                      Case Control Cards                                      $
    $HMNAME LOADSTEP               1"loadstep1"       9
    SUBCASE        1
      LABEL loadstep1
    ANALYSIS NLSTAT
      SPC =        1
      NLPARM =        1
    $HMNAME LOADSTEP               2"loadstep2"       9
    SUBCASE        2
      LABEL loadstep2
    ANALYSIS NLSTAT
    CNTNLSUB YES
      SPC =        1
      LOAD =        9
      NLPARM =        1
      NLOUT =        4
    $$ HYPERMESH TAGS
    $$BEGIN TAGS
    $$END TAGS
    BEGIN BULK
    $$  Stacking Information for Ply-Based Composite Definition
    $HMSET        5        1 "set1" 18
    $HMSETTYPE         5 "non-ordered" 18
    SET     5       GRID    LIST
    +       2158833 2158834
    $$$$ Contact definition
    $HMNAME GROUP                  1"CSurf_pin_CSurf_gear_fuelpumpside" "CONTACT"
    $HWCOLOR GROUP                 1      48
    $$  CONTACT Data
    CONTACT        1   SLIDE       1       2                        -0.037
    +                 CONSLI
    $HMNAME GROUP                  2"CSurf_Gear_outputside_CSurf_pin_1" "CONTACT"
    $HWCOLOR GROUP                 2      49
    CONTACT        2   SLIDE       3       4                        -0.037
    +                 CONSLI
    $$  Nonlinear Parameters
    $HMNAME LOADSTEPINPUT        1"nlparrm"
    NLPARM         1      10     0.0                      25
    $$  Output Parameters
    $HMNAME LOADSTEPINPUT        4"loadstepinput4"
    NLOUT          4NINT          10
    $$  Global SPC Data
    SPC            1  212226  123456     0.0
    SPC            1  212227  123456     0.0
    $$  Also SPC Data ends of Pin ( Blue part)
    SPC            1 2158834  123456     0.0
    SPC            1 2158833  123456     0.0
    $$  SPCD Data
    SPCD           9 2158834       4 6.28319
    SPCD           9 2158833       4 6.28319
    ENDDATA
  • Sid_22073
    edited April 2023
  • Adriano_Koga
    Adriano_Koga
    Sid_22073 said:
    I have 2 loadcases:
    - press-fit
  • Sid_22073
    edited April 2023
    Thanks for the answer.
    Is the SPCD i.e enforced rotation given to both ends of the shaft ?
    Did you use friction ?
    If possible Can you please share the model ?
    Kind regards,
    SId
  • Adriano_Koga
    Adriano_Koga
    edited April 2023
    Sid_22073 said:
    Kind regards,
    SId
    the model was there in my reply.
    I've used SPC directly to impose rotation to one end only, attached to the RBE2.
    I've used friction, otherwise there would be no decrease in torque, right?
  • Adriano_Koga
    Adriano_Koga
    edited April 2023
    i would add CONTF output in order to check the change in contact status, from stick to slip, when slippage starts to occur.
  • Sid_22073
    edited May 2023
    Thank you very much !!
  • MaxvS
    MaxvS Altair Community Member
    Hi guys, first of all thank you very much, with your help I was able to set up my contact slip case. But I am not sure if my result in the spc moment is correct. Similar to your results @Adriano_Koga
    My moment is 1 - 10^7 Nmm, which is very high in my opinion?
    I have a 50 mm shaft with a shaft ring of 49.78 mm and a diameter of 70 mm. There is contact between the two components with a friction coefficient of 0.15.
