I am working on a simulation of Rivet installation. Everything is modeled with solid elements. The rivet is with Elform 14 and rest of the parts are with Elform 24. I am comparing results to experimental data. I am comparing to load versus deflection curve. I am getting the same shape curve but the load is 2000 N more from simulation.
I tried contact type 7, Type 19 and Type 25. In all cases I get the same result. (CONTACT PARAMS ARE BASED ON RECOMMENDED VALUES)
The simulation was also run with LS-DYNA (in the same published paper) and they obtained the same result as experiment.
Please see attached result of my simulation.
Any suggestions and help is appreciated.
Thanks!
