I am experiencing difficulties calculating the impedance across frequencies for a 50 cm dipole antenna model, which is covered with pure water and PVC. Despite attempting to modify the radius and mesh size of the model, I have been unable to resolve the issue.
 Additionally, the following error messages appear:
 The following message from the master process (MYID= 0):
ERROR 116: The ratio of the segment radius to length is too large
See also message in the output file halfsheathdipole_wire_fr_1_ada_1.out
ERROR 31061: ADAPTFEKO run will terminate now due to error in RUNFEKO
 I have tried adjusting the geometric parameters and mesh segmentation of the model, but I am still unable to obtain the correct impedance values. Could you please advise on what settings or approaches might resolve this issue?
 I would greatly appreciate any guidance you can provide.
Best regards,
NoYa
