Hi. I'm doing a analysis using RADIOSS solver.
I analysis about rigid pole impact and the model composed to 4 components and one rigid pole.
The cover and side components are connected by bolting and I use rigid and spring elements to describe bolt connect.
And the tie constraint(Contact Type 2) are used to model to connect base and side componets.
But the analysis stop due to contact error.
How can I solve this problem?
Please help me and I attach my RAD file.
Thank you.
