Hi guys,
I found this description about user defined body force in acusolve documentation.
I want to activate turbulence equation (like k-e) for my problem. I found in the literature that when using momentum source (along with original NS equation), we also need to modify turbulence equation as:
Is it possible to modify standard k-epsilon model equation as above in acusolve using UDF? I am able to modify the original NS equation and add body force term as mentioned in the acusolve documentation.
I want to specify custom source terms for the different types of solved transport equations. Is it possible to add body force term for k and epsilon equations in acusolve using UDF?
I know we can define turbulent viscosity using UDF in Ansys fluent and modify transport equations for SA, k-E and k-w turbulence models. It does the same as I mentioned earlier. Is this doable in acusolve or hyperworks cfd?
Thanks!
