EDEM Calibration Kits
Elis Bright_20685
Elis Bright_20685 New Altair Community Member
edited March 2024 in Altair Exchange
Overview
The EDEM calibration kit is a collection of EDEM models of bulk solids characterisation tests that are commonly used to provide benchmark measurements for EDEM material model calibration and the associated EDEMpy post-processing scripts that automate the results extraction from these tests.
More information about the calibration kits can be found here.
Additional information about EDEM material model calibration can be found here.
Calibration Kits:
Pre-Requisite
EDEM
Usage/Installation Instructions
The documentation on the usage of the scripts can be found under each respective calibration kit.
Welcome!
Welcome!
