Altair RISE
Nominate Yourself Now!
AcuFieldView OpenGL error
User: "hafidz"
Altair Community Member
Updated by hafidz
Hi all,
I'm scratching my head with AcuFieldView  crashing on my server, where I got an error when launching AcuFieldView with the Graphic Error message :
Check FBO memory requirements. Also check the console window for the error message.
I also copied below all the content of the MS-DOS window when AcuFieldView tried to launch.
Loaded 2 plugin toolkits
AcuFieldView using FB rendering.
WarningL detected OpenGL error 'invalid enumerant'
Problem: 2D_Case_01_1 runId: 1 Working directory: ACUSIM.DIR
Displacing coordinates using end step mesh displacment field.
Unstructured gird 1 has 66812 nodes and 65525 elements.
Error: glGenBuffers not supported by OpenGL driver
FYI, we already set the environment variable FV_RF_GRAPHICS = 1  but the issue still persists.
Please find our machine specification below.
Server: Dell PowerEdge R740
OS: Windows Server 2012 R2 Standard 64bit
CPU: Intel Xeon Platinum 8276 2.2g, 28C/56T, 10,4GT/s, 38.5M Cache, Turbo, HT (164W) DDR4-2933
RAM: 128GB
GPU: NVIDIA® Tesla T4 16GB Passive, Single Slot, Full Height GPU
Please any help would be grateful !
Thanks,
Hafidz
1 - 8 of 81
    User: "acupro"
    Altair Employee
    Updated by acupro
    First thing to try is to make sure your graphics drivers are up to date.  Does that make any difference?
    User: "Nazrin"
    Updated by Nazrin
    Hi Hafidz,
    Please check whether Tesla can be use for graphical usage as i believe it is made for computing. AcuFieldview use gpu for rendering and as far as i know, for nvidia, RTX and GTX series can support rendering program such as post processing programs (AcuFieldview), rendering (video editing/games) etc. Please correct me if i am wrong.
    User: "hafidz"
    OP
    Updated by hafidz
    already try latest driver but issue still persists.  Can anyone confirm if this GPU can work with AcuFieldView?
    User: "acupro"
    Altair Employee
    Updated by acupro
    The OS is also quite old, and my not be supported.  Is there any other Display Adapter on the machine - or only that GPU?  (I'm trying to check on compatibility...)
    User: "acupro"
    Altair Employee
    Updated by acupro
    Are you trying to use remote graphics?  Or - are you displaying locally on that machine?  AcuFV (and FV in general) really doesn't support remote display very well.  You'll probably need to set up for client/server, where you run AcuFV locally, and access the data on the remote server.  You could also try adding
    -software_render
    to your start 'Target'.
    User: "hafidz"
    OP
    Updated by hafidz
    Other Display Adapter is 32MB Matrox G200eW3 (Nuvoton) WDDM 1.2 (Dell). Can you please confirm is the OS is supported or not?
    -software_render
    We are displaying locally on the machine.
    Where should I add this variable?
    -software_render
    Any other ideas?
    User: "acupro"
    Altair Employee
    Updated by acupro
    If you start from the desktop AcuFieldView icon, right-click the icon and select properties.  In the 'Target' entry, after what is there, add   -software_render   then hit OK.
    Or if starting from AcuSolve Command Prompt:
    acuFV  -software_render
    User: "acupro"
    Altair Employee
    Updated by acupro
    Did you also update the driver for the other Display Adapter?
