AcuFieldView OpenGL error
Hi all,
I'm scratching my head with AcuFieldView crashing on my server, where I got an error when launching AcuFieldView with the Graphic Error message :
Check FBO memory requirements. Also check the console window for the error message.
I also copied below all the content of the MS-DOS window when AcuFieldView tried to launch.
Loaded 2 plugin toolkits
AcuFieldView using FB rendering.
WarningL detected OpenGL error 'invalid enumerant'
Problem: 2D_Case_01_1 runId: 1 Working directory: ACUSIM.DIR
Displacing coordinates using end step mesh displacment field.
Unstructured gird 1 has 66812 nodes and 65525 elements.
Error: glGenBuffers not supported by OpenGL driver
FYI, we already set the environment variable FV_RF_GRAPHICS = 1 but the issue still persists.
Please find our machine specification below.
Server: Dell PowerEdge R740
OS: Windows Server 2012 R2 Standard 64bit
CPU: Intel Xeon Platinum 8276 2.2g, 28C/56T, 10,4GT/s, 38.5M Cache, Turbo, HT (164W) DDR4-2933
RAM: 128GB
GPU: NVIDIA® Tesla T4 16GB Passive, Single Slot, Full Height GPU
Please any help would be grateful !
Thanks,
Hafidz
Hi Hafidz,
Please check whether Tesla can be use for graphical usage as i believe it is made for computing. AcuFieldview use gpu for rendering and as far as i know, for nvidia, RTX and GTX series can support rendering program such as post processing programs (AcuFieldview), rendering (video editing/games) etc. Please correct me if i am wrong.
Are you trying to use remote graphics? Or - are you displaying locally on that machine? AcuFV (and FV in general) really doesn't support remote display very well. You'll probably need to set up for client/server, where you run AcuFV locally, and access the data on the remote server. You could also try adding
-software_render
to your start 'Target'.
The OS is also quite old, and my not be supported. Is there any other Display Adapter on the machine - or only that GPU? (I'm trying to check on compatibility...)
Other Display Adapter is 32MB Matrox G200eW3 (Nuvoton) WDDM 1.2 (Dell). Can you please confirm is the OS is supported or not?
-software_render
We are displaying locally on the machine.
Where should I add this variable?
-software_render
Any other ideas?
First thing to try is to make sure your graphics drivers are up to date. Does that make any difference?
