INERTIA RELIEF ANALYSIS
Above error is coming when i have tried to use INREL = -2 in my model. Please Suggest how to overcome from this problem. i have attempted many times but this error solver throws when i use INREL = -2. I'm applying above condition on pontoon boat. Rather than pressure i have applied Pressure force. In both scenario (i.e. Pressure & Pressure Force) same error is coming.
Thanks in advanced.
1 - 1 of
11
are you running the model in a network? It might be related to slow response from the file transfer where you're running your model.
Avoid running the model into network/cloud drives.
