apply displacement field
Dear all,
I want to apply a displacement field on nodes in order to apply a deformation according to that displacement.
I have a txt file (from CMM machine) containing x y and z coordinates (in z I have the displacement that I want to apply).
I create a field which read the txt file, however when I use the 'Realize' function, if I select displacement as a 'Field type' the algorithm does not work while, if I select 'Force' or 'Temperature' it works.
Do you have any idea why it does not work?
Thanks in advance,
Gabriele
1 - 1 of
11
Hello Gabriele
Please make sure that the displacement data is in this format :
Source : https://help.altair.com/hwdesktop/hwx/topics/pre_processing/entities/fields_r.htm?zoom_highlight=Fields
The reason is the displacement will have 6 dofs so each point will have 6 numerical values (3 for rotation and 3 for translation)
