Dear all,
I want to apply a displacement field on nodes in order to apply a deformation according to that displacement.
I have a txt file (from CMM machine) containing x y and z coordinates (in z I have the displacement that I want to apply).
I create a field which read the txt file, however when I use the 'Realize' function, if I select displacement as a 'Field type' the algorithm does not work while, if I select 'Force' or 'Temperature' it works.
Do you have any idea why it does not work?
Thanks in advance,
Gabriele
