Altair RISE
Nominate Yourself Now!
*** ERROR # 4965 ***  Maximum number of time increment cutbacks reached, analysis aborted.
User: "Teja_21569"
Altair Community Member
Updated by Teja_21569
I am running BOLT PRETENSION with gasket. I am Facing this error
analysis aborted.
NLPARM
Stick Contact
i am not able converge the results
1 - 12 of 121
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi Teja,
    Is there a reason for using stick contact type?
    Please share the .out file
    User: "Teja_21569"
    OP
    Hi
    Please look into the .out file
    Altair Employee
    Hi Teja,
    You are running a large displacement analysis which is not supported for gasket elements.
    Also, looks like there are some modeling issues. Please check contacts, loads, units and any modeling errors.
    Altair Employee
    Hi,Administrator:
    I'm a new beginner of using Hyperworks for analysis the Clips.
    The sub-case is quite simple:
    Here I got two parts in my simulation which i named them clip and bracket.
    I fix the bottom of the bracket and apply the force on the top of clip by a rigid element. After all settings, when i launch the optistruct , it calculation for few minutes,then comes the
    analysis aborted.
    I already searched all the internet for a answer but only find your topic.
    So could you give me a help?
    Enclosed are the .out and .fem files of my problem.
    I'm looking for your reply.
    Thanks.
    Altair Employee
    Thank you for sharing the files.
    I will check and get back to you soon.
    Altair Employee
    Hi,
    Can you run Large displacement analysis instead and check if that progresses till the end?
    Altair Employee
    Hi,there:
    Thank you for your support.
    I already modified the setting and launch the calculation,but the error is :
    *** ERROR # 4966 ***
     Minimum time increment reached,
     analysis aborted.
      I  have no idea how to deal with this error, i tried many tines.
    So, I come back for your help again.
    BTW , this time i change the material to nonlinear material with in TABLES1 ,and I am not sure I used them correctly.
    Altair Employee
    Hi @JasonJiang
    I see you have NLADAPT with some parameters. I think this is what causing the problem.
    I am running the same without NLADAPT and the analysis is half done (50% loaded). I will update if the analysis is through all errors.
    Altair Employee
    Hi,
    The analysis is through without any errors and converged. Please remove the NLADAPT and try again.
    Altair Employee
    @Prakash Pagadala
    Thank you again.
    Yes, you are right.I get the result after remove the NLADAPT .But  i find there has some elements penetrate each other, especially in contact area.
    BTW, Why are we remove NLADAPT? If we don't use the NLADAPT option, does it mean that the load is directly increased without changing with time increments?
    (NLADAPT – Parameters for Nonlinear Analysis to define time-stepping and convergence criteria  )
    Enclosed is the animation view of the result for you quick check.
    Altair Employee
    Hi @JasonJiang
    Can you change the stiffness parameter to HARD on PCONT card and check if that helps?
    By enforcing min and max increment, solver couldn't find a solution. So I removed it and let solver choose automatically.
    User: "LisaMontréal"
    Updated by LisaMontréal
    Hi,
    Could someone explain what does
    analysis aborted.
    mean ? What is the issue ?
