Material properties in Hypermesh.
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello...
I am new to Hypermesh and AcuSolve and will be using both to investigate flows in pipes.
I was wondering what is the Material option in Hypermesh for? Do we need to set our material properties in Hypermesh and then export the solver deck to AcuConsole? Or can we set our materials and material properties in AcuConsole?
Would appreciate your feedback. Thanks!
Welcome!
Answers
  • llyle_20499
    llyle_20499 New Altair Community Member
    edited November 2018
    Hi,
    Either way should work fine.
    You can set the material and export it as .inp and later import the .inp to AcuConsolve.
  • ydigit
    ydigit
    Altair Employee
    If you use the user profile > Engineering Solutions > CFD > AcuSolve you will get three material by default (Water_HM, Air_HM, Aluminium_HM).
    With the latest release 2017.3 most features of AcuConsole are implemented in HyperMesh. So there is no need to go to AcuConsole for most of the problem setups.
    If you are missing any feature in HyperMesh, that is present in AcuConsole please write to me.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2019
    How to know the material properties for flow distribution? For example I m putting material as rhodium n which material properties I need to use is mechanical properties , chemical properties ,thermal properties or physical properties
Welcome!
Welcome!
