Acoustic Infinite Elements
Hello everyone,
I am trying to define Infinite Elements on the boundary of the fluid elements.
I have a model setup with structural elements surrounded by fluid elements and then on the boundary of fluid Elements I have defined CACINF3 Elements.
Elements used: CACINF3
Property : PACINF
Pole Location: Defined in PACINF through X,Y,Z
Element normal: outward towards infinite direction
Results: Displacement (Pressure)
But I don't see any difference in result using Infinite Elements. Could anyone please help me, what am I still missing to define Infinite elements?
Thanks in advance.
I have refered these examples and have also prepared the model as per examples.
still I got 2 Errors.
1. Internal programming error
2. *** ERROR # 5824 ***
The microphone location, specified by grid ID 55586310, does not appear to be a
far-field point (located in the unbounded domain) with respect to any of
the infinite elements in the model.
I have attached a model. Could you please check what is still missing?
It would be a great help. I have already spent a lot time on it.
Thanks in Advance.
Vikrant Tailor
1. Internal programming error2. *** ERROR # 5824 ***
Thanks in Advance.
Vikrant Tailor
In the above shared tutorial, step 36 covers how to overcome error 5826.If possible please share the .out file of the run.
Sure, I will check it out.
meanwhile:
According to steps mentioned in pdf, normals of the elements are pointing outwards.
Still an error appears:
It seems you are running older version of OptiStruct version 2017.2.1.This feature was originally supported for direct method in OptiStruct 2017.2.
I see you are running modal method which is suppported for version 2017.2.2 and higher.Latest version of OptiStruct is 2019 .
Please refer attached example and tutorial for acoustic acoustic infinite elements.
