Acoustic Infinite Elements
Hello everyone,
I am trying to define Infinite Elements on the boundary of the fluid elements.
I have a model setup with structural elements surrounded by fluid elements and then on the boundary of fluid Elements I have defined CACINF3 Elements.
Elements used: CACINF3
Property : PACINF
Pole Location: Defined in PACINF through X,Y,Z
Element normal: outward towards infinite direction
Results: Displacement (Pressure)
But I don't see any difference in result using Infinite Elements. Could anyone please help me, what am I still missing to define Infinite elements?
Thanks in advance.
Answers
Please refer attached example and tutorial for acoustic acoustic infinite elements.
0 -
I have refered these examples and have also prepared the model as per examples.
still I got 2 Errors.
1. Internal programming error2. *** ERROR # 5824 ***
The microphone location, specified by grid ID 55586310, does not appear to be a
far-field point (located in the unbounded domain) with respect to any of
the infinite elements in the model.I have attached a model. Could you please check what is still missing?
It would be a great help. I have already spent a lot time on it.
Thanks in Advance.
Vikrant Tailor0 -
I have applied CD-1 to microfone grids in order to get pressure values.
for this, i get Internal Programming Error. **
Could you please refer above attached .hm file and give me appropriate solution.Thanks in advance.
Vikrant Tailor
0 -
Thanks in Advance.
Vikrant TailorIn the above shared tutorial, step 36 covers how to overcome error 5826.If possible please share the .out file of the run.
0 -
Sure, I will check it out.
meanwhile:0 -
According to steps mentioned in pdf, normals of the elements are pointing outwards.
Still an error appears:
the infinite elements in the model.0 -
It seems you are running older version of OptiStruct version 2017.2.1.This feature was originally supported for direct method in OptiStruct 2017.2.
I see you are running modal method which is suppported for version 2017.2.2 and higher.Latest version of OptiStruct is 2019 .
0 -
Thanks Rahul for drawing my attention to this cause.
I tried with Version 2018 and it's working successfully.
Thanks again.
Vikrant Tailor
0
