Altair RISE
Nominate Yourself Now!
Hyperview unable to load model/Hyperworks Failed to attach results
User: "Derek Neilson"
Altair Community Member
Updated by Derek Neilson
My tutorial model opens without a problem in AcuFieldView but when I try to open in Hyperview it is asking for a file reader type from a dropdown menu. I chose the Acusolve Result Reader. Checked the file path and it is good so I am missing something here.
Thanks
Derek
1 - 1 of 11
    User: "acupro"
    Altair Employee
    Updated by acupro
    As a workaround, you could try converting to H3D format and load that to HyperView.
    If you open the AcuSolve Command Prompt, go to the problem directory (looks like C:\Users\Derek\Desktop\cfd\manifold) and type:
    acuTrans  -pb  ACU-T1000_manifold  -out  -to  h3d  -ts  A
    This will create separate model and results files in h3d format.  If you want the model and results into the same file:
    acuTrans  -pb  ACU-T1000_manifold  -out  -to  h3d  -ts  A  -h3dopt  single
