Altair RISE
Nominate Yourself Now!
Saturable inductor array from text file
User: "Matthias Kehrer"
New Altair Community Member
Updated by Matthias Kehrer
Dear all,
I have the following problem:
I have a program/code which generates a high frequency model including parasitics,... and saturation effects for an inductor.
To use this model in PSIM I thought about a submodel which uses parameters form a text file.
Therefore, I wanted to generate a text file including the table/array, which can be inserted as parameter in my submodel.
However, the saturation model works when I directly type in the table, but not as a parameter from text file.
Same should be possible for a capacity with biased voltage (which I did not try so far).
Many thanks in advance!
BR
1 - 3 of 31
    User: "Rhonda_20369"
    Updated by Rhonda_20369
    Hi, Matthias,
    Presently, the Saturable Inductor block cannot read data from the parameter file.
    I have forwarded your issue to the development team. Hope they will add this functionality to the model soon.
    I have built a simple example circuit using a lookup table to implement the nonlinear characteristic of the saturable inductor:
    OP
    Hi Rhonda,
    many thx. I am quite new to PSIM. In the email you mentiond I should find the psim fiele somewhere attached. Where/how can I find it?
    BR, Matthias
    Hi Rhonda,
    BR, Matthias
    The PSIM schematic was attached to the support ticket CS0497760.
    Ticket Form for Case - Altair Support ticket CS0497760
