Saturable inductor array from text file
Dear all,
I have the following problem:
I have a program/code which generates a high frequency model including parasitics,... and saturation effects for an inductor.
To use this model in PSIM I thought about a submodel which uses parameters form a text file.
Therefore, I wanted to generate a text file including the table/array, which can be inserted as parameter in my submodel.
However, the saturation model works when I directly type in the table, but not as a parameter from text file.
Same should be possible for a capacity with biased voltage (which I did not try so far).
Many thanks in advance!
BR
Hi Rhonda,
many thx. I am quite new to PSIM. In the email you mentiond I should find the psim fiele somewhere attached. Where/how can I find it?
BR, Matthias
Hi Rhonda,
BR, Matthias
The PSIM schematic was attached to the support ticket CS0497760.
Ticket Form for Case - Altair Support ticket CS0497760
Hi, Matthias,
Presently, the Saturable Inductor block cannot read data from the parameter file.
I have forwarded your issue to the development team. Hope they will add this functionality to the model soon.
I have built a simple example circuit using a lookup table to implement the nonlinear characteristic of the saturable inductor:
