1 - 4 of
41
Hi,
load collector with card image set to EIGRL should be created and referenced under METHOD (STRUCT) in the normal modes load step.
thank you for reply,
I already change it but the error still occur during the analysis
*** ERROR # 23 ***
SID 2 used on Case Control data METHOD is missing in bulk data.
in my analysis, i only put constraint on my design.
Hi,
This tutorial might help you:
http://altairuniversity.com/wp-content/uploads/2013/08/modal_analysis_MG.pdf
