🎉Community Raffle - Win $25
Join and Win
Error 23
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Helo,
can any i help me to solve this problem.
 *** ERROR #  23 ***
  SID 1 used on Case Control data METHOD is missing in bulk data.
i want to run normal mode analysis. thank you
1 - 4 of 41
    User: "Simon Križnik"
    Altair Community Member
    Updated by Simon Križnik
    Hi,
    load collector with card image set to EIGRL should be created and referenced under METHOD (STRUCT) in the normal modes load step.
    This tutorial might help you:
    http://altairuniversity.com/wp-content/uploads/2013/08/modal_analysis_MG.pdf
    Altair Employee
    OP
    Hi,
    thank you for reply,
    I already change it but the error still occur during the analysis
      *** ERROR #  23 ***
      SID 2 used on Case Control data METHOD is missing in bulk data.
    in my analysis, i only put constraint on my design.
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Can you share us .out or .fem file of the run?
    Your shared file runs fine at my end. I see you are running linear static analysis. Just uncheck deform in subcase section. I feel units are not consistent in your model. Just maintain unit consistency and check the mass of the model.
