🎉Community Raffle - Win $25
Join and Win
How to plot Displacement vs Time graph for a Linear Static Analysis?
User: "Abdul Muizz Jamal"
Altair Community Member
Updated by Abdul Muizz Jamal
Hi, I hope you are having a good day. I have performed Linear Static Analysis on a component and I want to plot a graph for Time vs Displacement, stress, etc. When I go into the Hypergraph and use the h3D file it says that more than 10000 requests were detected. I don't know how to proceed with it and didn't find anything useful anywhere else. Please help me in this regard. I am attaching the image for the file folder which shows all the files after analysis has been performed.
Please help me. Thanks and regards
1 - 6 of 61
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    hi,
    1) linear static analysis is a static problem, meaning there's no time involved. Imagine that your load is applied very slowly, until it reached your maximum value. So, briefly, there is no way to plot a timexDisplacement. Only the final value.
    2) In HG, once you load your H3D file, you need to select which node you want to plot. HG cannot populate the full list of nodes with moore than 10000 nodes, then you need to filter and specify 1 node.
    OP
    hi,
    Hi Adriano, thanks for your reply. Ok if not time vs displacement then can we plot force vs displacement for Lienar Static Analysis? Thanks and regards
    Altair Employee
    hi,
    in linear static there's no curve, per say.
    It would be just 1 point, with your applied force vs final displacement.
    OP
    hi,
    Thank you for the response. I understood the scenario.
    OP
    hi,
    Hi Adriano, I hope you are having a good day. Can you please tell me how can I plot Stress - strain graph for a component? 2) S-N curve for Fatigue Analysis case in Hypermesh Thanks and regards.
    OP
    Hi Adriano, I hope you are having a good day. Can you please tell me how can I plot Stress - strain graph for a component? 2) S-N curve for Fatigue Analysis case in Hypermesh. Thanks and regards.
