Altair RISE
Nominate Yourself Now!
Optistruct ERROR 155
User: "kkandra"
Altair Community Member
Updated by kkandra
Hi,
I was working on optistruct and came across a new error and error description is given below:
A fatal error has occured during computations:
*** ERROR # 155 ***
Three numerical factorization in a row failed. Probable cause
is that there is a massless mechanism in the model.
Solver error no. = -729
subcase id = 1
Check the model and rerun the problem.
(osdiag,46,1 may be used to check for massless rigid body modes.)
(WARNING: results obtained with osdiag,46,1 cannot be used because
the model is changed internally.)
Can someone help me please?
1 - 6 of 61
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    I am having the same eeror message.
    I am just doing few experiment with RADIOSS for a few linear modal models.
    This is the error message:
    A fatal error has occurred during computations:
    *** ERROR # 155 ***
    subcase id = 3
    (MECHCHECK may be used to check for massless rigid body modes.)
    (WARNING: results obtained with MECHCHECK cannot be used because
    I have deleted the MPC parts in my model and now it is running.
    What it is wrong with my MPCs? Model check was saying that they were OK????
    Any help?
    Altair Employee
    I have the exact same error and don't know where its coming from. The model was running perfectly and I remeshed and it create this error! I have no where it comes from.
    Altair Employee
    do you have solve this problem?  i have the same problem !
    User: "kkandra"
    OP
    Updated by kkandra
    Check the element type and load type for the subcase. That might help is solving the problem
    Altair Employee
    If you are doing modal analysis (free free run) then increase Value of Vand number of modes to be extracted and see the error goes off.
    User: "ALI_22271"
    New Altair Community Member
    Updated by ALI_22271
    Helloo
    I am having the same problem, although I increased the value of V2 and number of modes to be extracted
    Any other way to resolve ??
