Optistruct ERROR 155
Hi,
I was working on optistruct and came across a new error and error description is given below:
A fatal error has occured during computations:
*** ERROR # 155 ***
Three numerical factorization in a row failed. Probable cause
is that there is a massless mechanism in the model.
Solver error no. = -729
subcase id = 1
Check the model and rerun the problem.
(osdiag,46,1 may be used to check for massless rigid body modes.)
(WARNING: results obtained with osdiag,46,1 cannot be used because
the model is changed internally.)
Can someone help me please?
I have the exact same error and don't know where its coming from. The model was running perfectly and I remeshed and it create this error! I have no where it comes from.
do you have solve this problem? i have the same problem !
If you are doing modal analysis (free free run) then increase Value of V2 and number of modes to be extracted and see the error goes off.
I am having the same eeror message.
I am just doing few experiment with RADIOSS for a few linear modal models.
This is the error message:
A fatal error has occurred during computations:
*** ERROR # 155 ***
subcase id = 3
(MECHCHECK may be used to check for massless rigid body modes.)
(WARNING: results obtained with MECHCHECK cannot be used because
I have deleted the MPC parts in my model and now it is running.
What it is wrong with my MPCs? Model check was saying that they were OK????
Any help?
