1 - 5 of
51
Why am I getting mm as unit here in hyperworks cfd 2022.1? If I want to change my unit back to m, how to do it? I remember, it was m in previous version of hyperworks cfd.
Thanks
For Sketch units, you can go to
File > Preferences > Sketching
and set your desired Units via the pull-down. Looks like the default is MMKS (mm kg N s) but you can switch that to MKS (m kg N s).
1 - 1 of
11
Thanks
i'm not a user of HWCFD but I couldn't find any mention of units in the release notes.
So it is probably depending on your input data.
I know that SimLab environment allows you to control unit systems.
