Why is my licence invalid
Julian_20293
Julian_20293 Altair Community Member
edited November 2022 in Community Q&A
Hello,
I have downloaded the Altair Inspire Student Edition but unfortunately I am unable to use the Programm.
Right after the Software has startet, the licence setupt popup appears with the notofication "Invalid licence". I have copied the licence file in the same folder as shown here: https://altairuniversity.com/altair-student-edition-licensing/
I have copied the licence protocol here:
11/03/22 20:30:08] System Error: No Auth Token in HHWU Config
[11/03/22 20:25:19] Releasing features...
[11/03/22 20:25:19] Invalid state for releasing
[11/03/22 20:25:19] Failed to release
[11/03/22 20:25:19] Trying activate features...
[11/03/22 20:25:19] Trying to activate...
[11/03/22 20:25:19] Deactivating features...
[11/03/22 20:25:19] Activating...
[11/03/22 20:25:19] Activating required features
[11/03/22 20:25:19] System Error during checking out: Altair License Manager: License error
Feature(s): GlobalZoneEU, HyperWorks, HWInspire
Error Code: 9
Error Description:
Feature not found
Feature: Inspire
Error Code: 6
Error Description:
[LOCAL] C:/Program Files/Altair/2022/Inspire2022/../security/altair_lic.dat - (Err: 9) Feature not found
[LOCAL] C:\Users\julia\OneDrive\Documents\Altair\2022\altair_lic.dat - (Err: 6) Unable to read file
License Path: C:/Program Files/Altair/2022/security/altair_lic.dat;C:/Program Files/Altair/2022/Inspire2022/../security/altair_lic.dat;C:\Users\julia\OneDrive\Documents\Altair\2022\altair_lic.dat
Feature(s): GlobalZoneEU, HyperWorksEDU
Error Code: 9
Error Description:
Feature not found
Feature: HyperWorksEDU
Error Code: 9
Error Description:
[11/03/22 20:25:19] Failed to activate
[11/03/22 20:27:11] Releasing features...
[11/03/22 20:27:11] Invalid state for releasing
[11/03/22 20:27:11] Failed to release
[11/03/22 20:27:11] Trying activate features...
[11/03/22 20:27:11] Trying to activate...
[11/03/22 20:27:11] Deactivating features...
[11/03/22 20:27:11] Activating...
[11/03/22 20:27:11] Activating required features
[11/03/22 20:27:11] System Error during checking out: Altair License Manager: License error
Error Code: 9
Error Description:
Feature not found
Feature: Inspire
Error Code: 6
Error Description:
Error Code: 9
Error Description:
Feature not found
Error Code: 9
Error Description:
[11/03/22 20:27:11] Failed to activate
what can I do to get the software running properly?
I really looking forward to your help, thank you!
Kind regards
Julian
Welcome!
Answers
  • Payal Pawar_20288
    Payal Pawar_20288
    Altair Employee
    Hi
    All the troubleshooting steps necessary for student license issues are here - https://altairuniversity.com/altair-student-edition-licensing/
  • Julian_20293
    Thank you for your reply!
    Unfortunately I have tried both ways (just clicking "activate" on the popup and setting an environment variable) but none of them works. Yesterday, the software worked for a short period of time until I had to close the app. As I tried to start the app again, the error shown in my last post appeared.
    Has anybody had the same error? ("ungültige Lizenz"/"invalid Licence")
    Thanks
  • Payal Pawar_20288
    Payal Pawar_20288
    Altair Employee
    Thanks
    Can you once check whether the Ethernet ID of your machine matches the Ethernet ID in the license file? Or else can you run ipconfig/all in the command window and send the output here?
    Please also ensure that the license file is named correctly. Use the windows folder option/view>display file name extensions, to make sure the file is named altair_lic.dat and not altair_lic.dat.dat.
Welcome!
Welcome!
