🎉Community Raffle - Win $25
Join and Win
Modal Masses are not shown in .outfile when running analysis via .fem deck file
Leon_21463User: "Leon_21463"
Altair Community Member
Updated by Leon_21463
Hello Everybody,
I recently wanted to automate my analysis a little bit. Since I have to run the same analysis again and again for different models I created a solver deck (.fem) file that contains all the analysis parameter, so I don't have to define them in the GUI for each model. The varying models are added to this deck with the 'include' command.
Everything is working fine so far and I get the same results as for the original model.
However, when I perform a modal analysis I do not get the modal effective masses or participation factor output that I usualy get in the .out file altough I used PARAM,EFFMAS,YES in my modal solver deck.
When I import the solver deck in the GUI and add the PARAM Control Card manually, I get the desired values.
So, is there a reason I don't get it when defining it in the solver deck only?
Any advice is greatly appreciated.
Thanks in advance and best regards
Leon
(Here is the solver deck is used)
1 - 2 of 21
    Adriano_KogaUser: "Adriano_Koga"
    Altair Employee
    Accepted Answer
    Updated by Adriano_Koga
    PARAM card need to be added inside the BULK DATA section.
    This means that it need to be after BEGIN BULK and before ENDDATA
    So, it should be:
    Subcases
    BEGIN BULK
    PARAM,......
    NODES..
    ELEMENTS...
    MAT...
    ENDDATA
    OP
    So, it should be:
    Subcases
    BEGIN BULK
    PARAM,......
    NODES..
    ELEMENTS...
    MAT...
    ENDDATA
    Hey Adriano,
    that worked! Thanks a lot.
    Best wishes
