Hello Everybody,
I recently wanted to automate my analysis a little bit. Since I have to run the same analysis again and again for different models I created a solver deck (.fem) file that contains all the analysis parameter, so I don't have to define them in the GUI for each model. The varying models are added to this deck with the 'include' command.
Everything is working fine so far and I get the same results as for the original model.
However, when I perform a modal analysis I do not get the modal effective masses or participation factor output that I usualy get in the .out file altough I used PARAM,EFFMAS,YES in my modal solver deck.
When I import the solver deck in the GUI and add the PARAM Control Card manually, I get the desired values.
So, is there a reason I don't get it when defining it in the solver deck only?
Any advice is greatly appreciated.
Thanks in advance and best regards
Leon
(Here is the solver deck is used)
