🎉Community Raffle - Win $25
Join and Win
What is the difference between TSTEP and TSTEP(time) in direct transient analysis
User: "Shiva Prasad"
Altair Community Member
Updated by Shiva Prasad
I'm doing a direct transient analysis , in the load step there are 2 options like TSTEP AND TSTEP(time) , I'm unable to find the difference between both. So I want what is the exact difference between both and when to use which.
1 - 3 of 31
    User: "Rajashri_Saha"
    Altair Employee
    Updated by Rajashri_Saha
    Hi Shiva,
    You can use TSTEP for Direct and Modal Transient analysis and TSTEP(Time) for Transient Thermal analysis.
    Thanks
    Rajashri
    OP
    Hi rajashri,
    Can you explain the reasoning behind this , because both options seems to do the same work .If you could elaborate it will help me.
    Thank you.
    Altair Employee
    Hi rajashri,
    Thank you.
    Hi Shiva,
    In Thermal transient load is due to Temp or Flux and in Modal Transient there is Displacement, velocity, acceleration, force etc involved for loading. that is why two different cards used for set up.
    Thanks
    Rajashri
