Altair RISE
Nominate Yourself Now!
How to be sure that the optimized composite layup drap well on the part
User: "moeen"
Altair Community Member
Updated by moeen
Hi
My question is that when i finally get the optimized results from optistruct for a composite laminate, How can i make sure that the physical ply draping on the manufactured part will be fine as well?
Is there a tool that can take care of draping so that the final ply outcome take into account that as well and thus the part can be manufactured without wondering if draping issues occurred during product manufacturing?
Thanks
1 - 8 of 81
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    there are two options to check layup draping:
    -Use the Drape Estimator to generate, directly into HyperMesh, draping angles and thickness variations resulting from the manufacturing process of fibers associated with plies in a composite laminate. You can use the drape data generated by this tool, based on inverse mapping, to improve the accuracy of parts modeled with composite materials. The Drape Estimator is available in the LS-DYNA, Nastran, OptiStruct and RADIOSS user profiles.
    ca084992d19b723d581a7ab3e01413011cdde07b.jpg?image_play_button_size=2x&image_crop_resized=960x540&image_play_button=1&image_play_button_color=54bbffe0
    Drape Estimator - Altair University
    -perform composite forming simulation with Hypererform (see HF-3090: Composite Forming Simulation)
    User: "moeen"
    OP
    Updated by moeen
    Thanks Ivan for the info, I have seen the video. From the video it seems like that once the layups are optimized (for my problem), we can run the Drape Estimator to see the changes in thickness and orientations. But then does it means that the ply orientations will change as well? like in above video, both 0 and 90 degree ply orientations changed after running draping estimator. So can one simply export this model and feed to machine where the composite will be manufactured with modified orientations coming from drape estimator?
    I want to know how does this draping info feed to the machine ?
    Thanks
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Have you done optimization in three phases? Freesize ,size and ply stacking optimization
    @moeen
    Drape Estimator will modify element level orientations and thicknesses with Drape tables for each ply. Ply level orientations and thicknesses will not change.
    Drape estimator simulates the effects of manufacturing process. Therefore I would use it before optimization.
    User: "moeen"
    OP
    Updated by moeen
    I am not sure when to use Drap estimator? before optimization or after?
    User: "moeen"
    OP
    Updated by moeen
    @moeen
    So if i use Drape Estimator first and than optimization would the final optimized part comply with the manufacturing and take into account the draping effects?
    Manufacturing compliance can be checked by reviewing orientation and thickness change output by the tool. Draping effects will be included during optimization.
    User: "moeen"
    OP
    Updated by moeen
    Thanks, I will do some examples and return back if there are more questions.
