🎉Community Raffle - Win $25
Join and Win
Cards to obtain Reaction forces
I would like to get the reaction force in a drop or crash test, similar to the examples below. What are the cards that I should include and what is the procedure to define it on the part that I am interested in ?
Thanks in advance.
1 - 2 of 21
    User: "PaulAltair"
    Altair Employee
    Accepted Answer
    Updated by PaulAltair
    Reaction forces are available for Rigid walls and interfaces
    In the starter, you can create a /TH/RWALL
    Select the Rwalls that you want output for and set output variable to 'DEF'image
    The output frequency is controlled by TFILE in engine, typically you would set it 10-100 times higher frequency than your animation files.
    If you have a meshed ground plane and contact, you would create a /TH/INTER for that contact instead of the /TH/RWALL
    User: "Ram Dhiwakar Seetharaman_21015"
    Altair Community Member
    OP
    Updated by Ram Dhiwakar Seetharaman_21015
    Thank you very much, Paul.
