Cards to obtain Reaction forces
Ram Dhiwakar Seetharaman_21015
Ram Dhiwakar Seetharaman_21015 Altair Community Member
edited April 2022 in Community Q&A
I would like to get the reaction force in a drop or crash test, similar to the examples below. What are the cards that I should include and what is the procedure to define it on the part that I am interested in ?
Thanks in advance.
Best Answer
  • PaulAltair
    PaulAltair
    Altair Employee
    edited April 2022 Answer ✓
    Reaction forces are available for Rigid walls and interfaces
    In the starter, you can create a /TH/RWALL
    Select the Rwalls that you want output for and set output variable to 'DEF'image
    The output frequency is controlled by TFILE in engine, typically you would set it 10-100 times higher frequency than your animation files.
    If you have a meshed ground plane and contact, you would create a /TH/INTER for that contact instead of the /TH/RWALL
Answers
  • PaulAltair
    PaulAltair
    Altair Employee
  • Ram Dhiwakar Seetharaman_21015
    edited April 2022
    Thank you very much, Paul.
Welcome!
Welcome!
