Impossible to install 2022.1
We're running into a problem with installing 2022.1 on all of our machines (various versions of Windows and types of workstations) with the following error:
Flexeraaxd$aaa: C:\[user path redacted]\AppData\Local\Temp\I1662736769\Windows_Pure_64_Bit\resource\iawin32.dll not found
at Flexeraaxd.af(Unknown Source)
at Flexeraaxd.aa(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.init(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.executeApplication(Unknown Source)
at com.zerog.ia.installer.Main.main(Unknown Source)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at com.zerog.lax.LAX.launch(Unknown Source)
at com.zerog.lax.LAX.main(Unknown Source)
2022.0 installs just fine, but none of the 2022.1 versions, being Simlab or HW install properly and all fail with the same issue...
add system environment variable JAVA_TOOL_OPTIONS="-Dos.name=Windows 7"
reboot
try again
btw,you may want to del the temp file created by the previous failed installaion,it's quite big,in:
C:\Users\YourUserName\AppData\Local\Temp\a folder name like I1665922024
Appreciate the help, this worked like a charm!
reboot
try again
