Altair RISE
Nominate Yourself Now!
Implementing nonlinear elastic spring element using type13 or type8
User: "Tetsuya"
Altair Community Member
Updated by Tetsuya
I am running a drop test of the landing gear model which consists of an arm, damper, and tire.
I am using a type13 spring element to model a damper for the analysis and would like to use the nonlinear elastic function.
According to the manual, using the function curve I can use a nonlinear elastic spring by activating H1 as 8.
However, I only found this only (H1=8) for type4 spring and not type13 spring nor type8 spring as can be seen from the picture.
How can I implement a nonlinear elastic spring using a force and displacement curve?
1 - 2 of 21
    User: "PaulAltair"
    Altair Employee
    Accepted Answer
    Updated by PaulAltair
    Hi, yes, the specific behaviour of H=8 is only available with Type 4 Spring, this is correct, and the manual states this too: Why do you need to use H=8 specifically? If you must use this, then you may use spring type 4 for your axial behaviour, but you must leave another spring (Type 13) coincident to constrain the other DOF
    all other 'H' types (H =0-7) are also nonlinear elastic springs with force/displacement input though, they just have different hardening behaviours. The simplest input is with H=0, the spring in this case will just follow the input curves for load/unload
    https://2021.help.altair.com/2021.2/hwsolvers/rad/topics/solvers/rad/stiffness_formulation_spring_hardening_r.htm
    User: "Tetsuya"
    OP
    Updated by Tetsuya
    Thank you for your reply. I thought when implementing stiffness vs displacement curve H=8 should be used. Perfect, I can just use H=0 in that case!
