Altair RISE
Nominate Yourself Now!
Can EDEM generated very loose packing, like porosity equal 0.6?
User: "Raheem Sterling_22160"
Altair Community Member
Updated by unknown
Hi everyone,
I need to build a packing with very high porosity with bond contact model, are there any method about it?
Thanks!
1 - 6 of 61
    User: "Stephen Cole"
    Altair Employee
    Updated by Stephen Cole
    Hi,
    In EDEM 2022 you can use the volume packing tool where you can set a porosity and you can use this with the bonding model.
    You can see information on the volume packing tool here:
    https://learn.altair.com/course/view.php?id=147&section=12
    Regards
    Stephen
    OP
    Updated by unknown
    Hi,
    Regards
    Stephen
    Hi Stephen,
    Thanks for reply, I have used "volume packing" in EDEM2021 before, but when I use volume packing, I don't need to create Factory which control parameters of bonding V2, so can I use volume packing and bonding v2 together?
    Thanks
    Raheem
    Altair Employee
    Hi Stephen,
    Thanks
    Raheem
    Hi,
    In EDEM 2022.0 the volume packing has been updated to include the option to set the bond time, this then allows you to work with bonding V2 like the standard factories.
    Regards
    Stephen
    OP
    Updated by unknown
    Hi,
    Regards
    Stephen
    Thanks, I found the settings, by the way, I have tried with bonding V2 many times, but I have never built bond successful, are there any examples or attentions when applying bonding v2?
    Altair Employee
    Hi,
    One of the key points is you need a contact radius larger than the particle physical radius.  In terms of guidance on the inputs I'd recommend reviewing the e-learning lesson on Bonding V2:
    https://learn.altair.com/course/view.php?id=148&section=4
    Regards
    Stephen
    OP
    Updated by unknown
    Hi,
    Regards
    Stephen
    Thanks, I set contact radius as you said and I usually used bonding old vcersion successfully, I will learn what you post, and in EDEM 2022 version, in Analyst-Line-Select element, I didn't see bond selection when I use bonding(cpu version), is it removed in EDEM 2022?
    Regards
    Raheem
