Hi everyone,
I need to build a packing with very high porosity with bond contact model, are there any method about it?
Thanks!
In EDEM 2022 you can use the volume packing tool where you can set a porosity and you can use this with the bonding model.
You can see information on the volume packing tool here:
https://learn.altair.com/course/view.php?id=147§ion=12
Regards
Stephen
Hi, In EDEM 2022 you can use the volume packing tool where you can set a porosity and you can use this with the bonding model. You can see information on the volume packing tool here: https://learn.altair.com/course/view.php?id=147§ion=12 Regards Stephen
Hi Stephen,
Thanks for reply, I have used "volume packing" in EDEM2021 before, but when I use volume packing, I don't need to create Factory which control parameters of bonding V2, so can I use volume packing and bonding v2 together?
Thanks
Hi Stephen, Thanks for reply, I have used "volume packing" in EDEM2021 before, but when I use volume packing, I don't need to create Factory which control parameters of bonding V2, so can I use volume packing and bonding v2 together? Thanks Raheem
In EDEM 2022.0 the volume packing has been updated to include the option to set the bond time, this then allows you to work with bonding V2 like the standard factories.
Hi, In EDEM 2022.0 the volume packing has been updated to include the option to set the bond time, this then allows you to work with bonding V2 like the standard factories. Regards Stephen
Thanks, I found the settings, by the way, I have tried with bonding V2 many times, but I have never built bond successful, are there any examples or attentions when applying bonding v2?
One of the key points is you need a contact radius larger than the particle physical radius. In terms of guidance on the inputs I'd recommend reviewing the e-learning lesson on Bonding V2:
https://learn.altair.com/course/view.php?id=148§ion=4
Hi, One of the key points is you need a contact radius larger than the particle physical radius. In terms of guidance on the inputs I'd recommend reviewing the e-learning lesson on Bonding V2: https://learn.altair.com/course/view.php?id=148§ion=4 Regards Stephen
Thanks, I set contact radius as you said and I usually used bonding old vcersion successfully, I will learn what you post, and in EDEM 2022 version, in Analyst-Line-Select element, I didn't see bond selection when I use bonding(cpu version), is it removed in EDEM 2022?
Raheem
