Problems running FSI heat transfer analysis with AcuSolve and OptiStruct
Lucia R
Lucia R Altair Community Member
edited May 2021 in Community Q&A
Hi,
I am doing a heat transfer FSI analysis with Acusolve and OptiStruct and it is running but the results are wrong because it obtains temperatures about 3e135 K.
I did the transient heat transfer analysis in Acusolve alone and it works correctly, and in Optistruct too, but when I conect both of them the results seem crazy.
Apart from this, the FSI is running from 3 days ago and it is in the time step 23 (the CFD analysis alone was completed in 6 hours).
Can anyone help me with this problem? I put below the files .log and .out of this problem.
Thanks in advance!
Welcome!
Best Answer
  • acupro
    acupro
    Altair Employee
    edited April 2021 Answer ✓
    Lucia R said:
    I don't have the 2019.0 version.
    I'm going to share with you the model files, can you try to run them in the 2019.0 version to check that it works?
    Thanks!
    The files are included in the following Drive link:
    https://drive.google.com/file/d/1hPyhdTMZRfYPj-yXuQBo_IjMedaOiOvn/view?usp=sharing
    The coupling for this does, indeed, work with 2019.0 of both solvers.  I did make a few changes to the AcuSolve .inp file.  I reduced min stagger iterations to 2 - as there's really no need to force a minimum of 4 - it will do as many as needed.  You don't need both Simple BC and External CS for the same surface - so I commented Simple BC.  I modified the pressure initial condition.
    I've attached the updated .inp file.
    The 2019.0 release should still be available through Altair Connect.  Make sure you check the box for 'Include Older Packages'.
    I'm still hopeful this will all be corrected/fixed for the 2021.1 release packages.
Answers
  • acupro
    acupro
    Altair Employee
    edited February 2021
    Starting with line 532 of the .Log file, it describes the External (optiStruct) surface then the fluid (AcuSolve) surface:
    acuSolve: Min/Max x-coord = 3.753500e+001 3.857000e+001
    acuSolve: Min/Max y-coord = -3.319230e+001 3.317798e+001
    acuSolve: Min/Max z-coord = -5.000000e+001 5.000000e+001
    acuSolve: Total surface area = 5.280686e+003
    acuSolve: Total length = 0.000000e+000
    acuSolve: No. external code mbds = 0
    acuSolve: No. fluid wet surfaces = 229566
    acuSolve: Min/Max x-coord = 3.673500e+001 3.937000e+001
    acuSolve: Min/Max y-coord = -3.299999e+001 3.299999e+001
    acuSolve: Total fluid surface area = 1.249814e+004
    The min/max dimensions are slightly different, and the overall fluid surface area is more than twice that of the structural area.  For the coupled analysis to work properly, the extent (size, shape, location, units) of the exchange surface need to be the same in each solver.  (The mesh doesn't need to be the same.)
    At the first time step, also from the .Log file:
    acuSolve: External-Code stagger "external_code":
    acuSolve: Ave distance = 3.836261e-001
    acuSolve: Max distance = 8.000000e-001
    This again indicates there is a mismatch between the surfaces in the two solvers - the average distance from the AcuSolve integration point to the OptiStruct integration point is 0.38, while the average is 0.8.  (Do we assume this is meters?)
    Please double-check to ensure the size, shape, location, units are represented the same in both solvers.  You should also make sure the temperature 'base' is the same, for example, that a value of 273 means the same thing in both solvers.
  • Lucia R
    Hi Acupro,
    I have modified the exchange surface and now it seems to be good (units are mm):
    acuSolve: Min/Max x-coord = 3.857000e+001 3.937000e+001
    acuSolve: Min/Max y-coord = -3.000000e+001 3.050000e+001
    acuSolve: Total surface area = 6.077552e+003
    acuSolve: No. fluid wet surfaces = 124896
    acuSolve: Total fluid surface area = 6.163713e+003
    But in the .log the time steps still wrong, I think that the units would be different in both models, but I don't know how to check this and change it.
    acuSolve: Time-Step= 2 ; timeInc= 1.000000e-002 ; time= 1.000000e-002
    acuSolve: Ave distance = 6.796082e-004
    acuSolve: Max distance = 1.111094e-001
    acuSolve: Min allowed gap = 6.130143e+074
    acuSolve: Max allowed gap = 4.516963e+075
    acuSolve: struct-heat res ratio = 3.732756e-003
    acuSolve: Min struct. heat flux = -1.944140e+000
    acuSolve: Ave struct. heat flux = -6.062449e-001
    acuSolve: Max struct. heat flux = 6.415443e-001
    acuSolve: Std struct. heat flux = 2.584384e-001
    acuSolve: Min temperature = -1.290625e+004
    acuSolve: Ave temperature = -3.878769e+003
    acuSolve: Max temperature = 1.985994e+003
    acuSolve: Std temperature = 2.307468e+003
    acuSolve: Converged
    How can I check the heat flux units in both models?
    Thanks for your help.
  • acupro
    acupro
    Altair Employee
    Lucia R said:
    Hi Acupro,
    acuSolve: Converged
    I'm not sure about OptiStruct - but AcuSolve (the solver) is unit-less.  The solver has no knowledge of units - it only has values/numbers.  Thus, it is up to the user to ensure those values represent a consistent set of units.  If you dimensions/lengths are in mm, then all units BCs, etc need to have values consistent with the length dimension being mm.  So density has to be be in kg/mm^3 rather than kg/m^3, etc.  Same for thermal properties, etc.  Most users find it simpler to represent all BCs, properties, lengths, etc. in MKS units across both solvers, in order to avoid confusion.  So that would be lengths in m, density in kg/m^3, etc.
    My guess would be that this is a case of values for properties, BCs, etc. being inconsistent with lengths represented in mm.
  • Lucia R
    I've represented all BCs, properties, lengths, etc. in MKS units across both solvers. AcuSolve seems to be running but an error occurs after some iterations (line 778 of the .Log file):
    acuSolve: Skipped
    acuSolve: CFL timeInc = 3.516369e-007
    acuSolve: Error receiving data from external code to message <stop false>; expected <stop> received <region_id 1>
    Do you know what is the problem and how to solve it?
    Thanks!
  • acupro
    acupro
    Altair Employee
    acuSolve: Skipped
    Thanks!
    I notice you're using version 2017.  It is possible there were problems with the exchange in that version.  Can you update to the latest release - 2021 - and see if that corrects the problem?  Based on the error, and the fact that the exchange information seemed reasonable, I would guess it's a problem with that version of the software.
  • Lucia R
    edited March 2021
    I updated to the release 2020 and now AcuSolve run all time steps but it seems that the exchange with OptiStruct is not working.
    I put below the .log and .out files, and also the cci file.
    In the .out file:
    Opening E:\MTR_Pila\FSI\unidades_m\3-FSI/cci.txt
    External Code via CCI: *** ERROR: Expected <send> but received <stop false> from AcuSolve
    External Code via CCI: *** ERROR: Received fatal error from AcuSolve in response to <temperature 180540>: fatal_error expected <stop> received <region_id 1>
    **** ABORTING RUN DUE TO UNEXPECTED ERROR CONDITION ****
    I hope you can help me.
    Thank you very much.
  • acupro
    acupro
    Altair Employee
    edited March 2021
    In the .out file:
    Apologies...  In searching through another similar thread, it appears the thermal coupling for AcuSolve / OptiStruct has some ongoing issues.  The previous suggestion was to try the simulation using AcuSolve and OptiStruct version 2019.0.  Are you using full version - or EDU version?  Are you able to download 2019.0 for both solvers and try again?
  • Junta_20361
    Junta_20361 New Altair Community Member
    edited March 2021
    2019 doesn't work neither.
    Actually, with the same input file, 2019 shows another error:
    like "external node not defined..."
    In 2020, it shows "the external code stagger skipped"
  • acupro
    acupro
    Altair Employee
    edited March 2021
    Is that latest with both OptiStruct and AcuSolve 2019.0?  Are you able to include/attach the .fem, .out, .inp, and .Log files?
  • Junta_20361
    edited March 2021
    hi Acupro,
    you can find the hm files for both acu and OS with the log file from below link:
    https://drive.google.com/drive/folders/1dh707P1Ykdy2eTMIlaUvTb9Gzp_284_9?usp=sharing
    thanks!
  • acupro
    acupro
    Altair Employee
    edited March 2021
    hi Acupro,
    thanks!
    It looks like you tried AcuSolve 2019.1.  Can you get 2019.0?
    It would be most helpful if you can include the actual model files from your latest attempt.  AcuSolve (.inp and MESH.DIR or HYPERMESH.DIR) and OptiStruct (.fem).  I want to test exactly what you tried, but it seems the files I exported from HM are not complete for the coupled solution.
  • Junta_20361
    edited March 2021
    hi Acupro,
    please find those solver decks in the attachment
  • acupro
    acupro
    Altair Employee
    edited March 2021
    hi Acupro,
    I ran these files without modification in 2019.0 - OptiStruct and AcuSolve.  There's an odd error message on the OS side at the very end, but other than that it all worked fine.  I believe the problem is on the AcuSolve side, so you need to use 2019/2019.0 AcuSolve (you may need to Include Older Packages), but I think you could use a newer OptiStruct version.  Hopefully this connection issue will be resolved in the next AcuSolve release.
    I've attached the Log files from the 2019.0 run.
  • Junta_20361
    edited March 2021
    hi Acupro,
    Thank you for you help on this,
    I will try with acusolve 2019.
    I also tried with version 2021. The error still exist with "external stagger skipped".
    Anyway, thank you very much!
  • Junta_20361
    edited March 2021
    hi,
    i would like to update about this. Using Solver 2019 for both Acu & OS
    If i run from Hypermesh, the error still occurs.
    But if i run from OptiStruct Solver Deck as below, the run can complete without error.
  • Lucia R
    edited April 2021
    hi,
    Hi,
    I have tried what you said in the latter reply but I obtain the same error: "Undefined external node..."
    Can anybody help me?
    I have tried with versions 2017.2, 2019.1 and 2020 and it doesn't work in none of them. Even I have tried to launch AcuSolve in version 2017 and OptiStruct in a newer version but it neither works.
    I don't have access to another versions, so I hope that anybody knows how to solve this problem.
    Thanks in advance.
  • acupro
    acupro
    Altair Employee
    edited April 2021
    Lucia R said:
    Hi,
    Thanks in advance.
    This will most likely only work with 2019.0 of AcuSolve and OptiStruct.  Are you able to obtain those base 2019.0 versions?
    Are you able to share the model files (consistent MKS for both solvers) here?  If not, it's probably best to contact your local support team - assuming you can share the files directly with them.
  • Junta_20361
    edited April 2021
    Lucia R said:
    Hi,
    Thanks in advance.
    hi Lucia,
    i tried 17,18, 19.1, 20 & 21.
    none of them work.
    But AcuSolve & OS version 19.0 can run very well for this simulation as acupro said.
    you should try with that version
  • Lucia R
    edited April 2021
    Thanks!
  • acupro
    acupro
    Altair Employee
    Thanks!
  • Lucia R
    edited April 2021
    Could you attach the solution files .h3d and .log or any screenshot of the results?
    Thanks.
  • acupro
    acupro
    Altair Employee
    edited April 2021
    Thanks.
    If you point me to a location where I can drop the files, I will do so.  I've attached the AcuSolve .Log and OptiStruct .out files.
  • acupro
    acupro
    Altair Employee
    edited May 2021
    In the .out file:
    This appears to be working now in the 2021.1 release version.
Welcome!
Welcome!
