VWT time required
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
How much time on an average is required for VWT to complete the analysis completely. I've been waiting since 4 hours for a simple circular plate simulation.
My computer specs are i5 2.2 gigs
8GB ram
2gb amd radeon m330 graphic card.
On an average, give me an estimate of a fine tunnel mesh and a coarse mesh for transient conditions both road and tires moving of an FSAE race car perfectly meshed in hm
I run with 4 cores. The green bar won't move more than say 20%
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited December 2015
    For even a simple meshed square plate, it shows JOB_NOT_STARTED in the command window
    The virtual wind tunnel analysis are not starting up
  • ydigit
    ydigit
    Altair Employee
    I would say a coarse mesh should be done in 1-4 hours on such a machine. (lots of assumption though).
    My guess is that you have issues with mesh generation and the run never started.
    Check if CAD.DIR and MESHSIM.DIR were created in the run folder (Name_ of_Run _time_stamp).
         This indicates that the meshing process was started. Open the file vwtAnalysis.MeshSim.txt in a text editor. This is meshing log file that indicates how far the meshing process went. In case volume mesh was successfully created, the last few lines of this file would be similar to:
    Please follow the trouble shooting guidelines on:
    http://forum.altairhyperworks.com/index.php?/topic/13776-workflow-for-virtual-wind-tunnel/&do=findComment&comment=20229
  • Altair Forum User
    Altair Forum User
    Altair Employee
    acuMeshSim: *** ASSERTION in Function <amsReadXml> File <amsReader.cpp> Line <62>
    acuMeshSim: *** There should be atleast one volume group
    Sim:
    Date = Thu Dec 24 14:37:28 2015
    acuMeshSim:
    Problem = vwtAnalysis
    acuMeshSim:
    Run = 1
    acuMeshSim:
    Hostname = SMAK
    acuMeshSim:
    Platform = Whistler 6.2 unknown
    acuMeshSim:
    Machine = win64
    acuMeshSim:
    Release = 13.0
    acuMeshSim:
    Release date = Jun  6 2014
    acuMeshSim: --------------------------------------------------------------
    What does it mean by there should be only one volume group. I have a simple rectangular meshed plate. And no free edges, so closed
    It is partly submerged in the road......
    BTW, thank you, ydigit
  • ydigit
    ydigit
    Altair Employee
    edited January 2016
    Can you post a screenshot of HyperMesh, with the mesh and the component tree  (in Model Browser)?
    Does the rectangular plate have a volume? Or is it only in one plane?  It would be best if you could upload the .HM file.
Welcome!
Welcome!
